1990 trimp pump removal 115 mariner
Sonof3m2
I am in the process of replacing my trim pump but i am having issues removing the original pump as there are some screws i cannot get to. I have the engine tilted all the way up and i still cant get to the screws. Cam someone help me with this? What is the best way to remove the trim pump? Thanks.
carholme
Re: 1990 trimp pump removal 115 mariner
What is your engine s/n? If you reply, I can send you the service manual and parts list so you can identify which system you have.
If you would like the service manual, PM with an email address.
Gerry
Sonof3m2
The serial is 0C289097. Email is smozham@yahoo, thanks!
carholme
That s/n comes up as:
MARINER - (115 H.P. (1990M ))
Serial No: 0C289097 Model No: 71154120D
Parts Listing for model 71154120D
Mercury Parts, (4 CYLINDER)
Service manual is on the way to you. Please let me know if you got it as I sent it to .com presuming that you are in the US. You didn't specify in your last post.
Gerry
Sonof3m2
Thank you! Ok i was able to remove the old pump/motor and installed a new aftermarket pump. I tested it out before installation and it worked fine. After i installation it worked for a few seconds and then a fuse blew, the relays got hot and the motor quit working. I removed the new motor and tested it again and it did not work. I dont know if i got a defective motor or i installed it incorrectly. My question is there anything i need to do before installing the new pump? All i did was just replace it assuming it would work. Was there something else i should have done first?
