1990 vs 1992 4.3 block swap
Chris51280
Ensign
I have a 1990 4.3 non balance shaft maercruiser with the 2bbl carb and fluid mounts. I found a 1992 4.3 automotive engine from an s10 for $50. I would like to have a backup maybe something to work on over the winter. I know I can only use the head and block with crankshaft the intake should still be the 12 bolt right? Does the balance shaft pull horsepower? I know the cam should work. Change tje freeze plugs.
any other things to consider? I have the mechanical fuel pump. Does that still work?
Chris51280
Ensign
Will there be a problem with the flywheel from a non balanced engine to a balanced engine? I think the non balanced engine had sone counterweights on the flywheel. Will this give me trouble
Chris51280
Ensign
I see that the only difference is that 1992 has the balance shaft. That is better anyways, right. So I can install the mercruiser camshaft and change freeze plugs and seals and have a marine engine.
Chris51280
Ensign
The fluid mounts should still work with a balanced engine. The manual #7 is good until 1993
thats because in 1993 they were still using motors left over from 1991 and 1992
no, the difference between the balanced and non balanced is significant
damper is different, flywheel is different, cam is different, block is different, timing set is different, timing cover is different.
because the damper and timing cover is different, the accessories - specifically the accessory drive brackets and pulleys on the front of the motor are different.
when they went to the balance shaft motors, the damper, flywheel and mounts became common with the 5.0 / 5.7 motors
Chris51280
Ensign
I asked the seller for the c/n to be sure. but sounds like there are just too many variances to make it work correctly. thanks for the help. I guess i'll stick with 87-91 models
dlogvine
Also you need to get a different oil pickup, oil pan, camshaft has different lobes in automotive engine vs. Mercruiser. All gaskets must be marine instead of the automotive. In 1993 they also changed the fuel pump from mechanical to electrical, so newer block with balanced shaft might require you to get a new fuel pump. Distributor must be also marine and not automotive. these are just a few differences I can think of on the top of what the other posts said.
Chris51280
Ensign
I would have just used the block and heads as a short block assembly. everything else will come from the old block. Combined with a mercruiser rebuilt kit should have given me a marine engine with balance shaft.
No it wont. your not understanding
your short block assembly is the Block, crank, rods, pistons, cam, balancer, timing assembly, flywheel.
that all must remain together. you cant mix and match parts.
and because the timing cover changed and the balancer changed from GM, Mercruiser had to change the accessory drive when they went to a balance shaft motor.
only the heads work on either block until 1995
either stick with all components from a non balance shaft motor which means get a different shortblock or rebuild the one in the boat now
or switch everything over to the mercruiser parts for a balance shaft motor which means getting all the stuff to bolt on the balance shaft short block to make it a mercruiser - accessory drive pulleys, brackets, belts, manual transmission flywheel for a balance shaft 4.3, cam would be close enough to use.
the block doesnt know what the crank has bolted to it
however with a 32 year old block, you have about $700 in machining (cleaning, line-hone, decking, boring, honing) prior to assembly
Chris51280
Ensign
I was just wondering since the unbalanced engines were tested and balanced at the factory. Drilled at the dampener and or flywheel. As long as I keep the rotating parts together. Like you said.
I wasn't planing on doing a complete overhaul. just rings and bearings if needed. New oil pump
Chris51280
Ensign
sure beats a cracked/welded block. I also need new exhaust risers. So I need to stay in some kinda budget
non balance shaft motors use different dampers and flywheels than balance shaft motors
if you are buying a different block, you cant use pistons you have laying around. so not going to be able to just do bearings and rings. while you may be able to slap it together, longevity wont be there and it would probably smoke like crazy
make sure your 87 block is a true 1987 block and not a left over 1986.
Chris51280
Ensign
The block has casting h103 on it where mine is a 011. From rapid marine I get a match for the 103 number
achris
More fish than mountain goat
Automatics tend to have flex-plates, not flywheels, so you'd need to source a flywheel for an non-balance shaft engine.
Chris.....
