fmt2bx
Thread starter- Joined
- May 27, 2015
- 217
It is 1 1990 Yamaha 130 ETXD. I have had trouble for the past few weeks now. Starts ok, idle fine, when going into high rpm (5500 or so) after a minute or so it starts surging/missing.(video)
If I throttle back (4000 rpm), it runs ok. Now if at 4000 rpm for long time, it starts acting up. If I let it idle for a bit then all ok until I get to 5000 + rpm.
Compression (1,2,3,4) 130, 135,130, 130
Running on ethanol free fuel 87 octane
prop 19"
Boat 19' Byliner capri.
Video here--------> https://youtu.be/t8cj_U_cvXU
-Cleaned both carbs 3 times now. Completely disassembled and cleaned.
-Change fuel pump
-Changed ALL fuel hoses (Boat and motor)
- Bypassed the fuel disconnect
-Changed primer bulb
-Ran from external tank
- open gas cap for extra venting
-Changed spark plugs twice
-Replaced fuel strainer (Motor side)
-Bypassed external fuel filter
- New stator
-New pulser
-New coils
- New plug wires and connectors
-New pack
-New rectifier
- Replaced impeller
-Replaced T stats
- Checked Alarm buzzer for oil and over temp, all ok
- Did a seafoam cleaning
- Battery charging ok
- Tach working and not erratic
- Checked and cleaned all ground connection
- checked all electrical wire connectors , looked ok
In the video, there is a bit about checking the fuel pump output at cranking, I do not have the equipment to check while running, don't know if output is normal. Was hoping someone could tell me.
I opened the control box and checked the ignition and emergency stop switches. Connectors seemed ok but didn't do a complete tear down. Was looking for obvious signs of problems.
I haven't looked into the oil system yet or timing.
I am running pretty much out of ideas of where this could come from. Fuel or ignition and what could cause that after all that was done so far.
I 'd appreciate very much any inputs.
Thank you.
PS: I d like to apologize in advance if I forgot to list some other things that were done. It has been a full time job trying to get this to run .
prop 19"
-Change fuel pump
- New stator
-New pulser
-New coils
-New pack
-New rectifier
- Replaced impeller
-Replaced T stats
Thank you.
