I have a 225 that runs fine for an hour or so (sometimes several hours). Idles fine, runs open fine, BUT at some point when you return to idle and engage the throttle, the engine will sputter, die and I cant start it again for hours (day). This motor has been to 4 different shops with consenus that carbs are bad. Carbs have been cleaned and refitted, plugs changed, fuel drained, refilled and stabilized with same results. Last shop said motor was repaired and they had run it for hour and a half with no problems. Took scouts out skiing and wham, same thing again. It never dies when running, only when starting from idle to increase speed. On board computer ($600) has been replaced.
