Re: 1990 yamaha 50 hp jet drive outboard
SDO NOT repeat DO NOT run that motor without the flush attachement. it DOES have an impeller ,just like an outboards, for engine cooling.<br /> 1 min and the pump assy is toatetoed and the kit is about 80 bucks.<br /> on the port side just above the "bubble" you will see a small plug, almost like an outboard drain plug, may say wash on it.<br /> the flush adapter is about 13 dollars and screws in place of that plug.<br /> outboard jet, for some reason , liked to use a seperate seawater pump on all I ever saw, berckly,hamilton sportjet and a few others did not.
