Paulbasstracker
Thread starter- Joined
- Sep 27, 2008
- 2
Can someone give me some input on this problem, I have a 1991 Mercury outboard that the overheat and low oil sensor starts to beep after you have been trolling for awhile. It will start out real faint sounding like it is shorting out and then stay on continually even if you shut the motor off and let it sit for a while. It sat all night one time and did the same alarm after it started in the morning, so I know that the motor was not overheating. There is plenty of oil and the water is coming out the back of the motor so it is going through the cooling system. I was wondering if it was a bad sensor or something more than that? If so are the sensors something you can replace or will it need to go to a shop?
