1991 15hp johnson fuel pump problem
toppyblue
The pump leaks when pumping the ball...I need to take the pump off and rebuild...How can you get it off? It is electric start.I was going to take the starter off for easier access but powerhead flywheel prevents this...Do I need to pull the powerhead to service the fuel pump???
boobie
Re: 1991 15hp johnson fuel pump problem
Could you post a pick of where the fuel pump is ??
