1991 175hp Black Max spark plug gapping
I haven't changed the spark plugs for this motor since I bought it, any recommendations on better performance spark plugs and what's the gapping on these motors?
Texasmark
Re: 1991 175hp Black Max spark plug gapping
None. Merc uses surface gap plugs for performance issues under certain conditions. Surface gap plugs have no electrode that you can move to adjust the gap. I have run SG plugs for 10 years on my 115 hp tower of power with stellar performance......Hence no reason to change them.
Mark
CharlieB
Most of the V6 motors use a surface gap plug, no adjustment is possible, it is built into the design.
Often NGK BUHW is listed but it should be verified in the service manual or NGK Catalog as there are a few difference heat ranges and you want to be sure that you use the correct one.
Faztbullet
1991 and up V-6's usually use the BU8H due to head/cooling differences....
