GeorgiaLineman
Thread starter- Joined
- Sep 3, 2012
- 8
I aquired this boat last year. Put new gas in and away we went. It ran great after a few tanks and then cold weather came and it sat. I did not winterize the motor (stupid me) and now the motor just isnt running good. I tried adding fresh gas to the 1/4 tank it had in it to no avail. The motor will idle but when given gas it bogs out immediately or will run at high RPM then bog down a few seconds later. I recently took the carbs off and cleaned them as well as I could (definitely not a boat mechanic) but I couldnt find how to take the jets out and clean them like I have done with my atv. Just wondering if this is a problem I can tackle or should I bite the bullet and take it to marine shop. I really think its got to do with carb combined with old gas but I'm not 100% sure. Also, I have noticed the oil pump lines and ball pump are hard as a brick, not sure if I should replace it with flexible gas line? Thanks for all the input in advance and if I can give anymore information on this motor just let me know! Thanks again!
