1991 48SPL Tilt Assist
MBJJ2369
Hi all,,
I am going to look at a 1991 48SPL and the owner says there is a problem with lift assist device. He says it is either a broken cable or control lever. I have looked through several postings and it seems as if this may either be an easy fix or a nightmare. Does anyone have any suggestions for me when I check out the motor???
Thanks
boobie
If it's a cable or a control lever it may be worth the fix. But if it's the lift unit itself it's questionable. That sells for $750.00. To rich for my blood. JMO.
boobie
Yes, but you'll have find a way to lock it down when you put the mtr in reverse.
