Theeplaymaker
- Joined
- May 30, 2012
- 41
Hello all!
I did something stupid at the beginning of this year (running it hard first time out of hibernation without a working tach) and toasted the top cylinder on my engine. I finally am getting around to figuruing out what I am going to do with it and I have some questions. I'll try to post pictures of the damage when I get a chance.
It came down to either try to salvage a few hundred bucks on this thing or try to tear into it and learn something. I have a factory manual and I am mechanically inclined but I have never delved into an engine before. I am going to try to do this project right but the cheapest way possible, yes they don't usually ever go together but I'm gonna try.
I am thinking this was caused by dirty carbs and a fuel issue since my primer bulb was messed up and I had some half *** looking fuel lines that I hadn't noticed before I took it out. Anyways it appears that a piece of piston ring or some type of metal got between the top of #1 piston and the head and put a bunch of indents into both.
I don't have this motor on the stand yet but will hopefully next week so I can't remember for sure but I don't think there was horrible scoring in the cylinder. Now for my questions and game plan.
1. I was planning on just re-ringing the other two cylinders unless something else causes me to change plans.
2. I am hoping that a hone job will be enough to clean up the cylinder on #1 and hopefully find a used/new piston somewhere.
I guess my main question at this point is: is this motor worth trying to do this on or are there certain dumb little things that will make it a pain in the butt?
Also is there anything specific I need to pay attention to during the tear down and rebuild?
I have to build a work bench and I plan on being organized/clean and label every nut and bolt in a bag.
Thanks for any ideas/tips/suggestions that may come and I'll hopefully be able to come here and get answers when the problems are bound to come up that I am not sure about.
THanks!
THanks!
