imported_fishbum
Thread starter- Joined
- Nov 7, 2006
- 4
Hello all,
I am new to the board. I have performed a search here and only further confused myself.
Problem: My 1991 Johnson Sailmaster 6hp is stuck in forward. I can't move the shifter into neutral or reverse. When I turn the prop I can see the top of the motor spinning so I dont think the actual transmission is jammed.
Confusion: Can I start the motor with the transmission in Forward? Someone suggested that I should get the motor running and then try shifting.
Next step: I think I should pull the lower unit off the motor to see if I can move the shifter then. Agree/disagree??
Thanks very much for any and all help!!
Jeremy
Jeremy
