roscoe
- Joined
- Oct 30, 2002
- 21,890
Re: 1991 70 HP Force low compression
Very good on the rebuild. I'm surprised you were able to use the piston, but I guess it wasn't damaged to badly.
DO NOT remove the screw in the front, inline with the propeller shaft.
This is the shift pivot crew. It will cause you all kinds of trouble.
The drain screw is under the torpedo, it is barely visible in the photo.
The top 2 screws are vents.
Remove all 3 to drain.
Fill from the bottom screw, allowing air to escape out the top 2 holes as it fills.
Insert bottom screw, then the 2 top screws.
