Mrkoolbreeze
Thread starter- Joined
- Dec 2, 2010
- 51
Hey fellas been reading this site for a while and would like to say it is an awesome and very helpful place. So anyway here it is this is my first boat and the boat was a gift from my dad and it sat for about 5 years in a barn .
so I did some research on it and found the transom was goo so I scooped it out which was very tedious I might add , tested the stringers in several areas and they were dry and solid ordered 10 gal. of nidabond and then I found the transom supports were goo as well sooo, off the top came and then I found the center stringer was rotten (the only one I had no access to with the top on) and the deck that was right under the batt. box and live well.
Next I pulled that part of the deck and removed the foam , the foam had some moisture but not really wet . I was wondering if this foam is structural and needed to be there or can I put just the pink foam boards in from HD.
I will attempt to post picks so bear with me as I am a rookie at this ,thanks in advance guys.
