1991 Chiscraft 252 crowne correct prop? and or help
danalbrecht
I purchased project boat 1991 ChrisCraft 252 Crowne OMC 5.7 liter Cobra outdrive. There was no prop, therefore I purchased a 14.8 diameter 15 pitch prop, took boat out today, wont come off plane or go over 10 mph, 2500 rpm max. If I put boat in neutral I can get 5,000 rpm..
Is this a pitch problem or something else,,, What size pitch should I have. Thanks
southkogs
To gain RPMs, you generally go down in diameter. But I wouldn't think you can afford to lose much more diameter on your prop. When you're on the trailer, can you get more than 2500 RPM in gear? (obviously with water flowing)
danalbrecht
Thanks for the reply I gave up for a little bit, heres where I am. 5.7 260 hp omc cobra dry weight 5900 lbs. 15 inch prop. new wires plugs cap rotor, changes spreadbore holley carb to Rochester, timing 8 degrees
Idles perfect, revs up past 5000 no problem in neutral
absolute pig under load me and 2 guys guessing 600 total will not get on plane
The best I ever had has 30 mph by speedo, not bad, long time to get on plane and 4100 rpms Only 2 people 1/2 tank gas no water
lately 3500 rpms wot wont plane
didn't come with a prop don't know what this should have and nobody seems to know
Ayuh,.... Sounds like it ain't gettin' fuel,...
Is the carb used,..?? is it workin' proper,..??
Hook a remote gas can to a fresh fuel filter, to the fuel pump, 'n try it,...
That'll eliminate the boat's fuel system side of it,....
southkogs
Have you weighed your boat?
Dry weight usually means without the drive/engine, but I think that's supposed to be combined weight for your boat. This is a cruiser, right? 27'?
