1991 DT55 Oil Injection Advice Needed...
fish2day
This engine set for 2 years and I cleaned the carbs and it started right up. I got 3 short beeps at full throttle, when I back off the throttle the beep stopped, but it had full power. I went home and cleaned the oil injection system, then it beeped loud by just turning the key in.Now it doesn't beep at all but runs rough without full power. All cylinders are firing. Is there a sensor that limits the CDI from allowing the engine to run correctly??
99yam40
Re: 1991 DT55 Oil Injection Advice Needed...
I believe Zuks have a oil flow switch that will set alarm and limit RPM.
But you may need to check compression to make sure you have not hurt the motor already
stylesabu
ir you keep running this motor without figuring out whats up,pre-mix your fuel in the meantime 50-1 mix
