stephenpence
Thread starter- Joined
- Jun 3, 2012
- 30
I'm trying to get my dad's old skeeter back up and running.. He?s got a '91 Evinrude 150 XP (VE150SLEIE) on back and I've been trying to piece together the puzzle by reading posts.. But I?ve hit this dead end. I've rebuilt the carbs and the engine now fires up fine, idles fine, but i took her out for her second run (first run never got above 5mph... hence the carb rebuild) and she sounded strong except the constant alarm sounded. But once I let her loose on the open water she never planed out, or pushed past 3000-ish rpm's. I tried reaching back and pumping the bulb when i had it at WOT to see if it gave her a boost, but nothing noticeable changed. the bulb was pretty collapsed, but it sounds like that is normal when the engine is sucking in the fuel? I also noticed the tach was only working sporadically, but when it was working or not didn't affect the performance of the engine again. I tested the compression of the cylinders when it was cold, and not really having run for 4 years, and they were all around 75psi. (Ranged from 72-76) From what I?ve read, that's low, but I?m hoping it's come up now that she's been on the water and run. I know the fuel lines are getting brittle as i punctured the primer bulb when i primed the engine to trailer the boat. With the constant alarm sounding as soon as I?d started the motor, it can?t be overheating, so it?s either the fuel vacuum alarm, or my temp sensor is shot.
1st set of tests (Fuel Starvation):
Under the advice of emdsapmgr and Bonairll I concluded the most likely culprit was fuel starvation. To test this, I ran the newly replaced bulb into a gas can sitting beside me in the boat. This way I could pump the bulb as it ran, and I knew there was no vacuum/venting issues with the tank. The constant alarm sounded as soon as I put her in the water and tried to start her. (once on dry ground.. when the boat is dry, it doesn?t seem to sound). I got her to operating temp and opened her up to WOT and still nothing past 3k RPMs (10-15mph). I hand pumped the bulb as it ran until it was hard, and still no change. The alarm continued to sound. At one point.. after I?d stopped the engine and caught a few bass, I kicked the motor on to move spots and the alarm, miraculously, didn?t sound. So I kicked her up to WOT and still nothing.. no change.. pumped and primed the bulb til it was hard.. no change even with the alarm off. When I got in, I checked the plugs, and the #4 plug appears to be fouled. (black, covered in a light film of gunk) while the other 5 seem to be great (light redish brown and dry). I started the motor and connected a timing light to the wire for the #4 plug and it pulsed like the rest of the wires did, so I?m guessing it?s just the plug. I can?t believe that one cylinder missing could be killing the motor like this though.
So.. my step #2 is to pull the fuel filter and clean/replace it, replace the fouled plug, and check the timer base to make sure it isn?t hung up and that it?s moving freely. Any other thoughts? With the engine maxing out at 3k RPM?s, could it be stuck in SLOW mode? (I?m not entirely sure the symptoms of SLOW mode with this motor, from what I gather though it maxs out at 2-2.5k rpms.. not 3k.) Because if it WAS in slow mode, paired with the constant alarm, I would think maybe that it is a faulty temp sensor or a grounding issue. (the fact that the boat doesn?t pick up performance when the alarm is OFF doesn?t lend any credence to this theory). Thank you for coming along on this journey!! Any and all help is greatly appreciated! There are exactly ZERO boat mechanics within 300 miles of where I live, so you guys are truly life savers!
