1991 Evinrude 155 com Overheating
Billy Henry
Re: 1991 Evinrude 155 com Overheating
I will order the parts put them in and let you know. <br /><br />thanks for your time!!
Dhadley
Anytime. I'm curious about what fixes the problem.
Billy Henry
OK,<br /><br />I don't have an VRO2 oil tank installed, When I paid this shady tree Boat Mech to find my problem he cut out the tank and told me that I don't need it. keep in mind the the motor was overheating before and after he pulled the tank. Do you think I should put it bacl in??
Dhadley
When he eliminated the oil injection did he unplug the harness on the pump?<br /><br />I really hope you put oil in the gas too.
andy6374
So obviously you are premixing now, right?<br /><br />It's up to you if you want to put it back. VRO2 are very reliable and 99% of the time it's either cracked oil lines or water in the oil that leads to problems not the VRO itself. So routine maintenance on the system, like everything else, is key. There is some good reading under the FAQ section here about VRO.<br /><br />Good luck and keep posting
Billy Henry
I am premixing, <br /><br />No I don't he unplug the harness, I want to use the VRO2 How do I check to make sure the pump is working.
Billy Henry
Sorry, I was rushing. No, I don't think he unpluged the harness.
Dhadley
If he didnt unplug the harness the horn should beep on and off to signal a "low oil" situation. Eventually it will go to a solid horn to indicate a "no oil" situation. If the harness is plugged in and the horn is not signaling then we need to find out why before you put the tank back in. <br /><br />Could this be the horn signal you are hearing?
Billy Henry
I don't know, I will unplug the harness and replace the T-stat and the valves and test the motor and you know. I don't expect the parts until next week.<br /><br />Thanks
Billy Henry
OK, <br /><br />I installed the T-stats and valves and I even replaced the head gaskets and I didn't even out of the marina before the SLOW Warning alarm went off. The harness was unpluged when I check it. <br /><br />What do I do next?
Bradster941
Umm, do you have an infra red heat gun? I would like to know what temp the heads read when the alarm goes off?<br /><br />Also, did you use perfect seal on the bottom of the SS plate when you replaced the H2o pump? Does this same thing occur on the muffs as well?<br /><br />(Just wondering if he’s sucking air at the pump). :rolleyes:
Billy Henry
I figured out the problem I pulled the powerhead and the last guy that worked on this motor put the wrong head gasket on it. The gasket was blocking one of the outlet holes.<br /><br />Thank for all your help
