Bannister 6905
Thread starter- Joined
- Jun 5, 2015
- 110
I have a 1991 Evinrude 40 with VRO.
Upon starting the motor for the first time, the warning buzzer began to beep - at about 1 sec intervals with frequency increasing as RPMs increase. The motor was lightly smoking during the brief time it was running. I found no leaks at the reservoir or at the fitting, and the hose was full of oil.
I immediately shut the motor down and check the reservoir - plenty of oil. I removed the oil line from the connector on the engine and reattached a clear vinyl tube and filled it with oil and restarted the motor. The alarm sounded again, but I could see that the pump was drawing oil into the pump, as the level dropped gradually. Again, the motor was smoking lightly during this time.
Any suggestions as to what I should do from this point? I am leaning toward removing the VRO and just running premix, but I know these systems are usually very reliable and are there for a good reason.
Any advice will be appreciated.
Thanks.
Bannister
Thanks.
Bannister
