Theeplaymaker
- Joined
- May 30, 2012
- 41
Motor specs to start off with:
1991 60 HP 3 Cylinder Evinrude TLEIB on a 16' Bass Tracker Nitro 160 TF
I am not a mechanic or I wouldn't be here but I am not motor retarded, I did a good bit of stuff to this motor over the winter to hopefully make her last longer but I think I broke something...I did the service bulletin to relocate the pee hole to the top of the block-success. I deleted the VRO and went pre-mix-hopefully not my problem, I know I did this right. I had her out 2 weeks ago and ran it hard, easy, just cruised around all day and it was great! Ran a lot better with the new t-stat since it didn't have one before when it ran like *** around the docks and idling, no more with the new and updated T-stat. Last run before I brought her in and this knocking kicked in and it lost power. It ran fine on the muffs when home with no knocking, so I put some gas in her and took it down to the dock today suspicious for problems tho. Ran ok for 10 seconds then started knocking again. Needless to say I didn't take it out. Good fuel, plugs that are 1 year old but only have 5 runs on them, no compression test yet. I am looking for some solid help so whatever else I can supply please let me know!
Now for the videos.
This one is the launch that seemed to do her in. I believe the tach is correct so I didn't overrev but it has been acting up this year so maybe it is bad and caused me to break something. The problems started right after I stoppped shooting video.
Evinrude 60 HP out of the hole. - YouTube
This was at the dock today. Since it sounded good on muffs wanted to try to take her out but 10 seconds after I started it the knocing was back. This vid is after I had it started already.
How bad... - YouTube
Any more questions or needed info let me know. Really hoping you guys can help me on this one and that it isn't as bad as it seems to me.
Now for the videos.
