Re: 1991 Evinrude 90 HP No Spark
Disconnect the red plug on the wiring harness. Now check spark. Don't try to start it, you'll have no way to shut it off. If you have spark with the harness unplugged, your problem is from the plug forward. Probably the key switch or the kill switch. (You didn't pull the kill switch by mistake did you?)
