1991 force 120 decelerates after hitting top speed
Jiggz
Re: 1991 force 120 decelerates after hitting top speed
So with all the troubleshooting you did and finally resolving your problem, what do you think was you final diagnosis? Restricted fuel lines with faulty needle setting on the bottom carb? The restricted line problem should have easily been identified with the installed clear fuel filter between fuel pump and carb since it will ran empty or at least low fuel level when the engine starts to bog down at WOT. Unless, the bottom carb causes the bogging down before it becomes empty or low in fuel level. The combination of having two such problems made the troubleshooting difficult but you did it and learned a long the way. Congrats.
leej
Yes I agree it should've shown me with the clear filters but they never even started to run dry so i believe that my main problem was with the lower carb needle but the filters did need to be changed since I did find sentiment in them....so I have learned a lot through this and am grateful...now comes the retaining part....thanks again for all the help and advice
