1991 Force 50hp runs like poop
TheScharnells
I have a 1991 50hp force outboard that was stored for seven years. I took it out on the lake and it would not run faster than idle. I checked compression and it is good in both cylinders. I checked for spark and have none in the bottom cylinder. (When I took the plug out to test compression it was as clean as when I put it in)I am guessing bad coil but it is a big guess. Any help would be great. I have spent a lot of time and money fixing the boat and motor up and my wife was not impressed on our tip to the lake. :(
TheScharnells
Re: 1991 Force 50hp runs like poop
Sorry forgot the model number it is 508F91C<br />Serial Number is 031560<br />Thanks,
roscoe
To test the coil, swap it with the other one.<br />If the other plug doesn't fire after the swap, you know it is the coil.<br />A bit pricey, but you can handle it.<br /><br />If the problem stays on the first plug, then you are looking for a new CD module.
