Cannondale
Thread starter- Joined
- May 22, 2010
- 278
OK, bought a 1991 Force 70hp motor a few weeks ago to repower my 16' Quantum bass boat. It ran well initially, but yesterday the starter began turning very slowly and then not at all....only a click when turning the key.
So, lacking a volt/multimeter right now, I began a "poor man's" diagnosis of the problem. Did check all fuses before beginning anything and all are good.
So, first, due to the starter motor turning slowly, I thought the starting battery was a bit low on charge due to it sitting for a few weeks in the cold, so I threw a charge on it. According to the charger, it was a bit low but not bad. Anyway, the charging of the battery didn't make a difference...still only getting a click when turning the key, no starter motor activity at all.
Next, I jumped the neutral lockout switch wires, essentially removing it from the starting circuit, but that didn't make a difference....still no starter motor activity.
Then, I fed 12V directly to the starter motor from the battery via a jumper cable. Starter motor turned over as soon as the voltage was supplied.
So, this leaves me one option....the starter solenoid. It's the only thing in the starting circuit left, right? Cannot think of anything else in the starting circuit I missed. The stator, rectifier, etc. are all in the ignition side of things and wouldn't prevent the starter from simply turning, right?
Any other thoughts before I order a new starter solenoid?
Thanks.
Thanks.
