- Joined
- Jul 18, 2011
- 19,161
OK, boat restoration fans, here we go . . .
I started pulling things apart today to take a look at the extent of the rotted bulkhead and stringers in my boat. Just to re-cap, I had the engine out over the winter and discovered the structural issues as a result. So, it looks like I should fix things before I put the engine back in the boat.
Of course as nature would have it we have not had much snow this winter, and finally got some this week (Covering the boat). Then this morning it rained, just to make the snow heavier to shovel. Anyway, here is a series of pictures that I took during the the process this afternoon, once it stopped raining.
BTW - this is my first post using the 'PhotoBucket/URL' method of posting pictures . . . hopefully it will work out.
Here is the deck hatch assembly which gives access to the fuel tank and stringer system area . . . It is about 7-8 feet long and also houses the ski locker.
Here is the Deck Hatch Assembly removed . . .
The rear bulkhead and the 'Culprit" areas that were not glassed over properly at the factory (wooops, did I say that ??? ). The plywood has shrunk and cracked over the years, allowing moisture to propagate into the wood. You can see the dry rot extending forward into the port side stringer
The visible rot extends about 2 feet forward along the stringer, but additional inspection with the fuel tank removed will be needed to see if it goes further.
The forward bulkhead is also showing early stages of rot stemming from a fastener hole . . . (darkened area)
A nice crack in the forward portion of the port stringer . . . upon closer inspection, it appears that this is from a piece of fiberglass mat that broke loose from the top part of the stringer right at the visible height step. Most likely from impact stress (I knew I should have slowed down before I hit that wave).
Anyway, The stingers look like they are made of knotty pine . . . I hope it is at least southern yellow pine ?!?!? (probably Doug Fir) They are not fully glassed in, as there is glass at the lower portion tabbing them into the hull and then glass on the top, giving them strength (but not quite enough) . . .but there is no glass in between, just resin coating.
I was not impressed with what I found . . . I wonder if I can take the boat back on the warranty . . .
So, upon initial inspection, it looks like the rear bulkhead is pretty well vaporized . . . dry rot has worked its way forward on the port side and worked its way aft on the starboard side.
Next steps: Remove the fuel tank for a more thorough inspection of the hidden areas and then formulate a repair plan. Anybody need some gasoline ???
