ConnieMarie
Thread starter- Joined
- Apr 29, 2014
- 44
Well i am starting to really appreciate the headache of boat ownership. Earlier this year I was having difficulty starting the boat in the water replaced the distributor cap and seemed to somewhat fix the problem. I am still having problems starting the engine cold most of the time. Often times it will take a while and numerous attempts at WOT to start. Once it does start it may run for a short period of time and just cut out or it may stay running. Sometime when I get her going on the water right after initial start up she will run fine and just cut out suddenly while cruising. After I have gotten a good ride in approx. 10-15 minutes she will run fine the rest of the day. Recently, when I do get it started it squeals very loudly until I either raise rpms or the engine idles down. The squeals go away after the initial start up and drive, never to return until the next cold start up. I think the carb may need a rebuild it often smells rich, and I should mention when I have difficulty starting I will leave WOT to kind of air the engine out before trying to start again, this often helps. Any advise or areas to look would be greatly appreciated.
I have replaced wires, plugs, dist. cap, fuel filter. Tested solenoid and fuses. Is there a procedure to adjust the carb?
