inlandNWcruiser
Thread starter- Joined
- Jul 19, 2009
- 5
I recently bought a 1991 15hp Gamefisher. As I understand it, this is a Force outboard made by Mercury. I'm not at all a marine mechanic so am looking for some repair advice. So far, I have only done a few minor maintenance repairs - replaced the water pump impeller, thermostat, spark plugs, & broken primer bulb. So far I have only run it at home in a tub of water. The motor starts right up and seems to run well. I am getting lots of cooling water coming out the spray hole.
First - the motor is smoking a lot and smelling strongly of gas. I am still running it on a gas/oil mixture that came with it from the previous owner. So I need to get some fresh gas and oil and give it a try but wondering if there is any specific gas or oil that I should try or other things related to the smoke/gas that I should look into.
Second - I got my hands on a service manual and decided to replace the 2 exhaust cover gaskets as suggested in the manual, but not sure where these are located on the motor, and could use some pointers on how to get to them and replace them.
Third - When I went out to tinker with it today I found a small amout of black oil leaking out of the cooling water intake port. This seemed abnormal to me. Should I be concerned? When I replaced the water pump impeller I also replaced the plastic water line seal that the copper water tube hooks into, but no other seals. The water pump shaft seal looked OK. Do I need to replace it? And there any other seals or gaskets associated with the lower unit? I am planning to replace the lower unit gear oil shortly and will look for any water in the oil.
Thanks in advance.
Thanks in advance.
