1991 gt 150 missing badly around 3000 rpm
Motor was running perfectly the night before but today after I topped up the gas at the marina (which only sells premium) it started to miss badly at around 3000rpm ? I had to come back to marina at 15 miles an hr so it would not miss fire .
dingbat
Check your fuel filter.
Marina fuel is notorious for water contamination. Go out of my way to avoid them
Filter is two days old , took filter off and dumped gas into a jar ,no water but only got an inch of gas out of a filter the size of a cars seem like it should have more in it ?
Don’t think it’s slow mode as it is miss firing badly and didn’t do that when it went into slow mode once before when I first bought it , gt 150 has low hrs less than 500 hrs ,but of course the Honda kicker has thousands of hrs .
It would not run at all today so I Took the filter off and no gas in it the filter the ethanol in the gas made the gasket swell up so large it wouldn’t seal the filter so no way for the pump to suck up the gas .
dingbat
Did you fill the filter with gas prior to install?
They will not fill on their own.
If not, crack a fuel line on the motor (vent air) and pump the filter full with the primer bulb
Installed a Sierra filter with a water catchment and drain, also replaced all the gas line hoses with ethanol friendly hose ,seems to run very good now no miss firing ,I will take it out tomorrow and test it out .
