Toeboater
Thread starter- Joined
- Mar 3, 2011
- 6
Hello All. I'm hoping somebody here can help me with this problem. I bought this motor last year and just getting around to getting it ready for the water. I replaced the charge coil and power pack assembly, noting here that I had to replace the flywheel due to nearly having to beat it off because it refused to budge. Yup, had to resort to using heat and an air hammer after breaking at least 1/2 dozen number 8 bolts with the puller...but that's another story.
I also rebuilt the carb to OMC specs as well as the fuel pump. Installed new plugs and replaced all fuel hoses.
This motor starts and runs strong in gear in a test tank but spits rather violently after it warms up and unless it is running at a higher rpm, it will sneeze and die. The thing that puzzles me most is that when it sneezes or spits, it's not from the carburetor but from the small hole on back of the fuel pump where the pin on the spring loaded "push rod" pokes through. Manual recommends 1 3/4 turns out for carb mixture for initial start and I've been all over the place after that, chasing the sweet spot. Also, did not replace ignition coils since they seemed to check out with ohm-meter. I have ordered a new set of plug wires but I'm not convinced that will cure the problem.
Anybody have an idea what is causing this? I would certainly appreciate it.
Thanks
Thanks
