1991 Mecruiser alph drive knocking nooise
jallen100
I just bought a 91 Thompson 21.5' with a Mercruiser 4.3 Alpha and I have a bad knocking noise. Its not from the engine but it almost sounds like a rod knocking. It went away as I trimmed the boat but then cam back. The boat runs great but that noise is awful. Any ideas?????
Don S
Re: 1991 Mecruiser alph drive knocking nooise
Remove the outdrive and start it up and see if it's still knocking. Won't hurt anything to run it for 15 seconds or so to see what happens.
Ayuh,... Pull the drive, 'n try it, atleast you'll know which end is the Problem...
If it's the motor, rebuild or replace...
jallen100
Gimbal bearing was toast
Don S
If the gimbal bearing was bad, I would bet you have a lot of other problems also. Like water in the bellows ?????
jallen100
Yep and I had to replace the bellows also.
