1991 Mercrusiser 3.0L with alpha shift interupter adjustment
kryan2
Will someone be so kind to forward me the link to the factory manual so I can set my shift interupter switch with cables.
Thanks
Don S
Re: 1991 Mercrusiser 3.0L with alpha shift interupter adjustment
Since 91 was the change over year, do you have an Alpha I or an Alpha I Gen II outdrive? Makes a big difference. Even a Merc SN for the drive would help.
kryan2
Outdrive serial number is 580837
Don S
What is the LETTER in front of the number?
Ayuh,.... If you're attempin' to adjust an issue that recently started,...
You probably need a New lower cable, rather than Just an adjustment...
Old cables wear out,... adjustin' 'em Back is rarely sucessful...
Tell Us the symptoms,+ the Problem ya got...
kryan2
The letter is O D.
Cable is good......i adjusted it a bit and can only get forward to shift nicely.
Thanks for looking out for me BOND O
KR
kryan2
Thanks again.
kryan2
Anyone assist me with this?
