richw46
- Joined
- Apr 7, 2008
- 118
On the left side of your transom mount is a tilt lock. On the bottom right of the mount is a white nylon pressure release screw. Turn it counterclockwise and then you can lift the motor and flip the tilt lock to hold it in place.
I'm not sure why you need the flywheel tool and I don't have a reference on a cherry picker; is that a lifting device to take the motor off the transom?
Here's a link to a video I made for replacing the O-Rings in the piston. It will start where I show the locations for the nylon screw and how to set the tilt lock. You may need someone to flip the lock while you lift the motor
