1991 Sea Nymph SS 175, 90 HP Johnson, Rebuild.
budski
[No message]
jigngrub
This area^^^^ begs me to...
Do this vvvv
Bow rider seating is such a waste of valuable fishing space!;)
budski
Hey Jign, It has 2 front livewells 1 on each side.
bonz_d
Nice rig. Seeing more and more of these styled boats being set up to pull planer boards for walleye rather than slow trolling for bass. Overall it looks pretty solid.
budski
No Title
Got her mostly gutted, the floor was not to bad but decided to replace it, the flotation is good thank God, would have hated to have to take it all out and replace it, this boat is really well built, transum is solid. going to install new vinyl floor and some of the carpeting.
Watermann
Yeah Lowe the parent company for SN has been around a long time and they do make some pretty solid boats. Someone is going to enjoy a nice boat but please say your getting rid of the head knocker seat. :lol:
64osby
Looks very clean under the deck compared to most of the tin hulls we see around here. Lucky you!;)
budski
No Title
Got most of the new floor built and vinyl applied, only dry fitted so far.
sprintst
Nice to see you at it again. Looks nice under the deck...so much of a time saver.
Frey0357
Nice boat ya got there Budski! Make sure to completely check that foam.....all the way to the bottom of one of the poured in "blobs"....mine was dry, very dry on the top, but the last 2" was soaked! Hopefully you have dodged the foam bullet and dont have to worry about it! Good luck on the project, I for one will be watching!
How was working with that vinyl?
Frey
budski
Thanks Sprint it sure does save time and it;s dry all the way down to the aluminum floor Frey, makes things a lot easier, working with the vinyl is pretty easy, glued it down and glued all around the edges and wrapped it about one inch around other side glued and stapled it with SS staples.
budski
No Title
Got the bottom side panels carpeted, finished the vinyl in the bow, and the floor screwed down with ss screws.
dozerII
Holy-Cow John just found your thread and your only 14 posts into it and your already closing the deck up. Great project.
Frey0357
Great work there Budski! I'm still tearing mine apart.....:eek:
Keep the photos comin'....
Frey
budski
No Title
Yes Glen, this a quite an easy project, the transum and flotation are good, the floor was iffy so replaced it as well as with vinyl flooring, got the bow platform and hatch doors carpeted, made the walkway shorter and the platform 8 inches longer, going to put a bow seat base there.
budski
No Title
Got the bow done.
64osby
Speedy Gonzalez! Look forward to see what you do to clean up the paint.
jigngrub
Everything is looking real good Bud!
Kind of disappointed to see you didn't do the bow deck in vinyl, but carpet is much easier when you have to deal with hatches.
What kind of adhesive did you use for the vinyl?
