1991 Searay 225 BR Transom and Stringer Evaluation
GCartwright
Thanks JAS, I will give that a try,
One other question, I somehow ended up with 1/2" chop strand in my online order which isn't worth returning, I've since picked up 1/4",any benefit or problem using the 1/2" to pb the transom in?
kcassells
Nope, Soak em first i the resin. When they are saturated they will fall to the bottom. Then add the catalyst and mix.
AShipShow
as Kev stated, nothing at all wrong with 1/2" chopped fibers... actually, they are stronger... most people usually just go with 1/4" since its a little easier to work with. Some people even use milled fibers which are way small, but I like knowing theres some strength to my PB.
GCartwright
thanks guys, 1/2 it will be
​​​Made ade a mistake earlier with what I said about the transom thickness, right now with csm on both sides I'm right at 1.6" plus .30" for the hull
AShipShow
Two layers of 1708 on the inside and the pb behind and should be right on the money
GCartwright
I'm jumping ahead a bit but the original transom shown in the picture was not tabbed in the lower section, the tabbing stopped where the angle changes at the stringer
I made the new transom slightly bigger so that there's more meat in it where the lower part of the transom plate mounts.
I want to fill in the area around the drain with pb and get some tabbing in along the bottom edge but that would cause a lip and a flatness issue..
Could the center part of the transom be skinned/ tabbed with two layers of 1708 or should I leave it like original
Woodonglass
Install it, fill the drain cutout with PB, fillet ALL the edges and tab All sides. Why would it cause a lip and flatness issue? Pic doesn't show that.
GCartwright
Wouldn't a strip of tabbing at the bottom of the keyhole run accross the transom plate mount and cause a step?
Woodonglass
Not if you use a butt joint when you lay the 1708 across the full width of the transom and then follow up with the last full layer that covers the entire transom AND the tabbings.
GCartwright
Back at it's after a bit of a break to take care of some other things on the list, picked up a few heaters and lamps for some cool weather glassing, using a 8000 btu propane heater to bring the tented canopy up to temperature then electric and ir heat to maintain during gassing /curing
Transom is in using thickened resin, I'm happy with the results, got good squeeze out and inner transom seems parallel to the outer outer hull.
Tabbing and transom skin are on as well, going to have to do a bit of clean up with a few air bubbles, not sure what the white spot is to the right of the drain, must of been some sort of contamination on the glass,
There is a slight difference (. 010") between the tape roll and the full roll of 1708 which you can see in the picture, was surprised just how much more resin the thicker glass used.
Glad this part of the rebuild is done
GCartwright
Got a few more things done this past week, had a customer I do work for make me up a thickness jig, it measures 2 1/4" on the inner cutout, I'm right at 2 1/8" and parallel between inner and outer, need a helper on the inside to get better measurements since I need three hands
Going to pick wood for the stringers this week and have a question : if ACX uses c grade core plies then why use it if the only difference between it and CCX is one good face? Is that enough of a difference or does some ACX have better inner plies?
JASinIL2006
I think the only difference between ACX and CCX is a good face on one side. Some brands of plywood are better than other (e.g., more plies, fewer voids), but for something you'll never see, CCX would work just as well.
GCartwright
Well since I took special wood out I better put something special back in
GCartwright
Got some items crossed of the list on the weekend, I've had my motor on blocks in the corner of the garage for a year and a half and reading comments on the forum about an engine sitting and rusting made me get my butt in gear.
​​​​A company I do work for was throwing out material handling carts with nice locking casters so I grabbed two of them and hauled them home, cut them up, blew the dust off the welder and got to work.
I plan on changing the starter.... just because, compression check, replace impeller and belts, nice that I can now roll it away from the wall and get access.
Got tired of wrestling with my rolls of cloth on the ground out of the box so I put together a rack, now to clean my bench so I can use it
GCartwright
Had a bit of grinding left up in the bow area, picked up the plywood for the stringers, went with the arauco ACX, nice looking wood with minimal voids.
So question, the new transom will be very close to having one of the transom plate mounting screws partially exposed due to a taper in the keyhole in that location . It's the third hole up on the starboard side (picture of original transom shown) Should I drill the hole, see how much meat is left on the edge and fill the hole and tapered area of transom with epoxy and redrill if necessary or just build the area up with epoxy first? (I have some marine tex already)
GCartwright
2nd attempt at wrapping csm around the bottom of the stringer was better but still has spots were it wont lay down along the top edge. I put a 22 deg bevel in the stringer to match the hull deadrise which isnt helping get a tight wrap on the one side. Any point in bevelling the stringer or should I just go with this since its going to be set in pb anyway?
Chris51280
Ensign
looks better than mine. I had some spots on the top where i wrapped the csm over but i left it like that. it is still sealed and my cleats went there. csm does not add much to the strength of the stringer so it is mainly to seal the wood more than just the poly by itself
