1991 Tracker Pro Deep V 17 ignition issues
CarlosDanger
I recently purchased a 1991 tracker the owner lost the key so i would need to replace the ignition. After doing so im not getting anything when i turn the key. the gauge pops up the batttery has voltage but the engine does nothing. could i have installed the ignition incorrectly? does anybody have any troubleshooting tips on how to diagnose this problem? Battery is also rather old but took a charge. Any help is much appreciated
Silvertip
Yes - you likely installed it incorrectly. No pictures or description of what the configuration is now leaves us with nothing to go on. Remember, we can't see what you did. But -- the switch is labeled with letters and will appear something like this: "B" = 12 volts from the engine harness. "C" = push to choke switch from the engine harness. "S" or "I" = starter solenoid. "A" = to accessories. Finally the switch should have two "M" terminals = magneto. With key off, these two contacts short the ignition to ground thus killing the engine. In the run position these two terminals are open. Best I can do with limited info.
CarlosDanger
Thankyou! i now realize that i left too little info I'm going to start back on the problem and hope i can find my mistake. Thank you for the help!
airshot
Also check your battery, just because it takes a charge doesnt mean it will hold it....full battery is 12.6 volts and up, dead battery is 12 volts !! Under 12 volts means battery may not recover. Get it tested at you local auto parts store, normally the test is free. To often a good battery turns out to be not so good !!!!!
havoc_squad
Be advised that incorrectly wiring battery voltage into many outboard models engine shutoff circuits will likely fry the ignition system either disabling all spark, erratic spark, or the engine won't shut off spark when turned off.
You might have to fork out the money to replace the switchbox/powerpack. Don't spend any money on parts until the matter is fully diagnosed correctly.
FYI, this is a boat engine issue topic that would be in the Evinrude/Johnson outboard section from the look at your picture.
For Evinrude/Johnson around your year model for the key wires:
Yellow/Black striped is the kill circuit wire that goes to the ignition system.
Black is the ground wire.
Red/purple is the 12V supply from the outboard to the key.
Purple is the 12V supply that is turned on/off at the key that goes to the accessories it is attached to and back to the outboard to enable certain items (rectifier/regulator).
Purple striped white is the choke/primer solenoid 12V that enables these as long as the key is held pushed in.
Please do your homework and verify these things before changing things on your own outboard as the wiring situation on your boat might not completely match what is stated if it has been modified.
If the motor won't shut off even if you manually ground the kill circuit at the powerpack, the only options you have to shut it off are disconnect the gas and let it run out (not a good idea if the motor has oil injection), get the engine to low idle and turn the primer solenoid red lever to dump extra gas in the motor until it floods and dies, or get something to insulate your hands and pull all three spark plugs.
