Ok, I posted this three months ago and still have not been able to figure this out. Keep in mind, I've rebuild just about every kind of gasoline combustion engine you can imagine, automotive, marine, lawn mowers, chain saws, the small cox toy engines, even the big detroit 671 diesels - I've seen a few. I bought the SELOC manual which explained the ignition system and tested everything in the book, by the book (using a fluke). I ruled out the charging system and battery, verified proper voltage levels, I pulled, checked, cleaned all the plug connections and wires, everything that could be adjusted - I tried - only made things worse. I checked every sensor, CP, TP, Knock, TSwitch, TSensor. I tried higher Octane fuel(93). I've merticulously cleaned all 6 carbs - twice, I re-adjusted the carb linkage and oil injector linkage - FOUR times, verified fuel delivery, no blockage or cracks in the fuel lines. (a new fuel tank was installed early this summer when I got the boat) I finally got the chance to have the previous owner take the boat out last weekend, He hadn't been in it for over two years but by his recollection - it did the same thing with him for as long as he owned it, only he recalled the motor only pulling back once. Anyway, I have a see-through fuel filter plus the one in the engine that are both perfectly clean - Nothing, and I mean nothing I've done has had any affected WHAT SO EVER on this particular problem. It performs EXACTLY the same way EVERY SINGLE TIME, I can duplicate the problem every single time I throttle up to WOT. I'm convinced the YMIS is advancing the timing to the full 22 BTDC at WOT (like its' suppose too), going immediately to WOT, the boat plains and reaches a TS Of 42MPH, RPMS reach 54 (takes about 8 seconds, no cavitation), 5 seconds later, the RPMs INSTANTLY drop back to 49, boat slows to 36MPH, five seconds after that, RPMS INSTANTLY drop again to 46, boat slows to 31MPH, where it will remain ALL DAY LONG for as long as I am running the boat. If I slowly throttle up to WOT, the RPMS never reach above 46. Other than that, the motor has been completely reliable, NO other problems what-so-ever that I can tell. Someone told me the motor is still in the "Break-in mode" that the YMIS is not allowing the motor to reach full potential to allow for a "Break-in Period" set by the dealer. Is there such a thing? I plan on wringing out the pulser coil next (the boat is stored in another state, so I can only work on it during the weekend - which interfers with my fishing) I think maybe one of the pulsers is defective (???), Then again, This is a smooth strong clean running engine - NO MISSING, (yes, I checked the plugs, they ALL look normal) I did find a bad Spark plug cap and replaced it, but it made no difference what-so-ever to the main problem, other than it did seem to run just a little smoother. I checked all 6 Ignition Coils with a meter, (which is how I found the bad cap) I just can't figure it out. Another Idea I had was the Knock sensor, it shows 580Mohms, it should be infinity, but when I disconnected it - the motor ran considerably worse. The book says the YMIS only takes input from the KS input if not getting input from the CP and TP sensors. There is no O2 sensor. I have not checked compression but judging the way it jumps out the hole (will throw you out the boat if you don't hold on) I don't see this being a compression problem, plus hot or cold the problem does not change. I also intend to put a timing light on it to verify if it is indeed the timing, hard to do on the water at WOT though. The P owner also told me he blew a fuse once (the small round one, next to the two big square ones) and ended up having to replaced the computer. (it is the correct PN) I need some real technical insight here, not backyard warrior feedback. I've spoken to several outboard motor mechanics and dealers and they all gave me a different answer (I checked everything they suggested). The 250 seems to be a rare engine (???) Nobody I talked to seemed to have much experiance with that model. Keep in mind, the 225 and 250 is way different from other YAMI models (it is the most advanced YMIS covered - unquote). I'm also looking into getting a diagnostic test harness.
