1991Johnson gt150 over heat alarm
i was flushing saltwater out of my motor with the garden hose after fishing on the ocean for the day and after seven minutes overheat alarm went off , could this be because my well has next to no pressure right now and wont even run a garden sprinkler? Water was coming out of the bottom of motor casing just like it was all day .
Thanks boobie i will put it back in the ocean and test it out as soon as i get the kicker running , the chinook are calling ! Do you know how much water should be coming out the exhaust when its hooked up to the hose .
The wild fire smoke happened ,then i had problems with the van i use to put boat in water ,so spring it is or ian now test it at home with the muffs when it stops raining .I put a 3000 gal cistern in with a 3/4 hp motor so now i will not have a low pressure problem .
