1992 -115hp
Dhadley
Re: 1992 -115hp
OK, with the flywheel upside down look at the magnet on the center hub. Not the outer magnets, the one on the center hub.
What does it look like? Is it flush with the hub? Is the epoxy still smooth or does it look like the rubber in a spun prop hub?
Is there a white dot or line on the flywheel close to the hub?
punchy
Re: 1992 -115hp
everything under the wheel looks good I did'nt see a white mark of any kind.
I put new spark plug wires on it this week.All i had checked was for a spark there was fire at each plug so i figured they were ok.Well a friend told me to ohm them ,should be 3 - 3.5 ohms.I checked them all four checked weak or bad.THAT WAS IT this boat gets on plane like it did new.
Thanks everyone for the help I think this problem is fixed.d:)
