1992 150 johnson compression
hydrasports
I took compression on my 1992 150 johnson today,I decarbed,ran her at the lake and then put in neutral at wot while cranking. 105,102,103,91,94,99 From looking at numbers on here,Im worried that they are too low and not even ? Hope its not time for repower :confused:
Joe Reeves
Re: 1992 150 johnson compression
Capt..... The later model V/6 OMC engines such as you have, had their compression factors lowered to compensate for the poor quality gasoline that has been on the market. Also, many of the V/6 engines would show a difference, pertaining to compression, on the port bank as compared to the starboard bank.<br /><br />Frankly I never undrstood this and have inquired about it from a couple OMC reps. I received a answer that the difference resulted due to a crankshaft design (still don't understand it). However, as the saying goes, that's the nature of the beast. <br /><br />Bottom line is that your readings are pretty well within specifications.<br /><br />NOTE.... A word of advice, DO NOT open the throttle on any outboard engine when in neutral. You could very well encounter a runaway engine. In which case, you could have a connecting rod come flying through the side of that crankcase with the force of a grenade! (Not a good idea.)
