1992 2.5 offshore tach hookup
Yardsale
Has anyone hooked up a quicksilver tach to a 2.5 offshore? I could not fin a plug for a harness. thanks
Dukedog
should be a gray wire under tha dash.. tha other end should be plugged into a gray wire on one of tha rec/reg..... thats tha "signal" circuit... did tha boat not come with a tach or are you jus now adding one?
Yardsale
Boat never had a tach. Motor and control box were installed at a later date. My OMC has a plug for a tach harness on my other boat. I was hoping Mercury had something similar.
Dukedog
tha merc stuff should have it!... what harness and controls are ya workin' with?.. motor year?
Dukedog
merc harness, both boat and engine harness will have wiring for a tach.. it will be a gray wire for signal.. from reg/rectifier to tach......
copy and paste tha below in your address bar and enter... it will ope a pdf that has all you will need............
file:///C:/Users/allys/Downloads/Old%20Downloads/MODELS%20135-150-175-200-225%201992%20and%20Newer%20_%20135-150-150-%20XR6-150%20Magnum%20III-150%20EFI-175-175%20EFI-.pdf
