1992 3.0 mercruiser wiring diagram
grizzreaper
Hello everyone. I have a 1988 StarCraft islander 21 ft with a 1992 3.0 and I was cutting and rewiring .I cut and now I have no power to key switch. Where can I get a new wiring diagram for this.
grizzreaper
Thank you. I will print this off at work tomorrow. I have more info on the main plug. It has a 10 ga black wire. 10 ga red wire. Gray/purple which I took off oil pressure gauge, yellow/red, white(ish) , gray, gray/White, pink(ish) . On the ignition it ign terminal, acc terminal, batt terminal, and raised terminal that has st.
Ayuh,..... Ignition should be a purple wire,...
The battery should be a red wire,....
st means Start, which is the yellow/ red wire,.....
wiring color codes are standard [h=2]American Boat and Yacht Council Standards[/h]
BlackGroundNegative / Neutral Main Return
Blue-StripeTilt up and or trim outTilt and or trim circuits
BrownAlternator Charge LightGenerator Terminal or Alternator Auxiliary Terminal to Regulator
Generator ArmatureGenerator Armature to Regulator
PumpsCircuit Breaker or Switch to Pumps
Brown w/YellowBilge BlowersCircuit Breaker or Switch to Blower
Dark BlueCabin & InstrumentCircuit Breaker or Switch to Lights
Green or Green w/Yellow StripeBonding SystemGrounding Wires (if insulated)
Green StripeTilt down and/or trim inTilt and or trim circuits
GreyNavigation LightsCircuit Breaker or Switch to Lights
TachometerTachometer Sender to Gauge
Lt. BlueOil PressureOil Pressure Sender to Gauge
OrangeAccessory FeedAmmeter to Alternator or Generator
Common FeedDistribution Panel to Accessory Switch
FeedAccessory Circuit Breakers or Switches
PinkFuel GaugeFuel Gauge Sender to Gauge
PurpleIgnitionIgnition Switch to Coil & Electrical Instrument
Instrument FeedDistribution Panel Electrical Instruments
RedInstrument FeedDistribution Panel to Electrical Instruments
Power FeedsPositive Main Power (particularly un-fused)
TanWater temperatureWater temperature sender to gauge
YellowGenerator FieldGenerator to Regulator Field Terminal
Yellow w/RedStarting CircuitStarting Switch to Solenoid
COLOR ITEM USE
