pvanv
- Joined
- Apr 20, 2008
- 6,586
Ok Pvanv if i am reading your post correctly and after thinking about it. What your saying is the push rod clutch is not actually connected to anything? So what i need to do is get in there with some long needle nose pliers and try to wiggle that push rod free and just pull it out? then put the steel ball then the push rod back into the prop shaft, then reinstall housing with oring and prop shaft seals. im guessing it just fell out and got wedged back there when i removed the prop shaft housing?
I also ordered a service manual, i suppose i should have started there.
Yep. Right on all. Just dump the push rod out onto the bench. Then clamp the gearcase in a vise with the opening horizontal, and reinsert the complete prop shaft housing assembly, complete with the push rod.
