Bill Riordan
Thread starter- Joined
- Jun 2, 2019
- 8
I think I have done everything possible and I can't solve this one, need some help.
Last year motor ran perfect all year, I had put a brand new impeller and pump housing in, no issues. This year the telltale is weak at idle, as soon as you put it in gear it stops altogether, a minute later it overheats.
So far I have:
HELP!!!! any ideas????
So far I have:
- Another complete new water pump kit, verified the channels in the lower unit are clear, yes the key is in and the rubber grommet that goes onto the discharge tube is in.
- Taken off the head, exhaust cover and lifted the powerhead up to make sure everything is clear.
- Tested the T-state in boiling water
- When the lower unit is off if I connect water from the hose directly to the pump tube it flows out the telltale no problem so all circuits are clear.
