Re: 1992 Astro Restoration
You have several options and none are guaranteed to be permanent, well one has a much better chance of holding up.
Sounds like you've looked into the problem and have an idea of what caused it, the problem is if there?s any water still in the laminate when you re-coat it its possible for them to return.
Just sanding off the gel coat and filling the pits then re-gel coating may hold up for a little while, but the blisters can return fairly easily because gel coat isn't a great moisture barrier and this is how water got to the laminate in the first place. Using epoxy to re-coat it works better, but can still fail.
The most reliable way to fix it and prevent the return is to grind off all of the gel coat and any blistered laminate, then dry the hull as much as possible, this can take months. Then you rebuild the surface with a layer of glass and epoxy, then fair the hull with epoxy and paint it. This creates a good waterproof (well, resistant) barrier to protect the laminate.
How you fix it is up to you and how you plan to use the boat.
You can do nothing and use it like it is, it may or may not get worse (could even look better during long periods of non use) and when its in the water only you and the fish know the blisters are there.
You can sand them off (and all of the gel coat) and re-gel coat it. This will be a good deal of work and may last, you just don?t know for how long though.
Sand them off and use several layers of epoxy to seal the hull then paint it. This will take about the same amount of time and money as using gel coat, but has a much better chance of holding up.
Grind them all off, dry the hull as much as possible and then re-glass with epoxy, this has best chance of success.
If it were me I would either leave it as is, saving the time and money for doing something else like boating or fishing. Or sand them off, dry the hull, then seal it with epoxy, then fair and paint it. I wouldn?t bother with gel coat, or the re-glass with epoxy, just gel coat doesn?t have a good enough chance of success for the effort and money, and re-glassing with epoxy is over kill for a low cost trailer boat.
