1992 Astro Restoration
Cadwelder
Re: 1992 Astro Restoration
I'm using polyester resin (unwaxed) so that part isn't a problem. Cure time is easy with poly by controling the amount of MEKP you add. But I may just go ahead and laminate while the fillet is still a little tacky, as you suggested, just curious if it would be a problem if I waited a couple days.
Yacht Dr.
I agree with glassing the trans in first..let cure..then quick prep..dry fit everything again..then glass the rest.
It may not be factory..but its IMO the Right way to do it. ( more steps that the factory couldnt afford ? ).
If you want perfect fillets then tape where you want the fillet to be..then fill and "spoon" ..peel the tape and juuust before it kicks off resin coat it..then glass when its still wet but after the heat cycle ..
Hope Im explaining well enough :) .
YD.
j_k_bisson
Yatch Dr. you explained everything but what's a "heat cycle"?
Cadwelder
YD.
Yep understand completly, thanks
Yacht Dr.
A heat cycle is the bike Micky Rourke had in " Harley Davidson and the Marlboro Man ".. ;) .
Its when thicker resin materials start to cure and gernerate there heat and cure cycles..
More mass of the resin ( like in a fillet ) the more Heat its going to generate during its curing process.
You dont want to do a large fillet and then start to glass over that before its completed its heat cycle or you will have a situation where it gets Way too hot in those corners ( A BIG NO NO ) becoming too brittle.
And another is when your laying up and those corners start to heat up..you have litterally NO time to wet and roll those inside radia and corners ( basically your new lams will almost instantly cure off before you can roll out ).
Big mess laying up on fillets before its time ;) .
YD.
Cadwelder
YD.
I've had it get so hot it blistered the exterior finish (in hot weather), before I learned to control things a bit better. I'll just let the fillets cure out till cold but still a little tacky.
Cadwelder
Had a friend of mine bring me a half gallon jug of some stuff call Laminex by 3M. He said it was better and eaiser than making your own peanut butter for fillets and he said it uses the same MEKP as the polyester resin. (He works for a place that makes fiberglass tubs). He swears by it. Is this stuff any good?
Cadwelder
They must make two products called Laminex, this one I have Label says Laminex Fillets. I googled it too (should have done that already). Write up is good, but always is from a product maker, was wondering if anyone has actually used it.
OK...dumb question maybe...what's the diff between fillet and fairing? Compound wise.
ahh..wait.... fillet is between the joints and covered with glass and fairing is more like a top coat that you can sand smooth. right? close? no cigar?
Cadwelder
Yes, sir that's is it. Fillets are a good thing too, but most manufactuere don't do it because of the cure times. The boat I'm restoring now didn't have fillets ran on anything, they just bridged the gap with fiberglass and let it ride.
