1992 camry
Johnson110
question, my camry was running perfect has 122k all tuned up etc, filled tank and next day car running bad engine idle bad and missing, put some dry gas and injection cleaner in engine, still running bad, car seem to run better when cold after heats up starts to run bad , wanderin coil bad? ignition wires bad? hate to start changing out parts at radom, anybody with same problem? Thanks for any replys!
ob
Re: 1992 camry
First item I'd check would be the fuel filter if a recent fillup was followed by poor running symptom.
Johnson110
Re: 1992 camry
ob, Thanks for the reply I was looking looking on other web site they say that the filter last a lifetime in these cars, i guess i will change it, now i have to find it first!
xtraham
Re: 1992 camry
what engine?
when was the tune up and what parts were installed?
I have seen them do exactly what you are describing and the distributor was cracked, actually came off in to pieces
and still running.......
puddle jumper
Re: 1992 camry
No fuil filter will last a life time and if it is pluged solid dont be surprised if the fuil pump goes soon after.
If a tune up was done check the plug wires for damage.
I think the fuil filter on that car is under the master cylender mounted to the firewall.
Just a thought but shouldnt have the fuil filter been changed at the time of the tune up.
Johnson110
Re: 1992 camry
Turns out that after letting it sit overnight, it is running ok now, maybe water in fuel, the engine is a 2.2 liter, bought the car from a freind of mine fuel filter was changed not that long ago, like i said after it sitting all night started right up in morning and ran fine all day, must have been water in fuel i put two can of dry gas in it! Thanks for all suggestions !
crazy charlie
Re: 1992 camry
So do you really think it is fine now???? I never heard of a car fixing itself.What you got was a warning that something is going bad and now is the time to figure out what it is because next time it will be worse.When was the last full tune up??? when was the timing belt changed if ever?? Sure no one likes doing preventative maintenance because "it aint broke" but you will save yourself a bunch of money if you fix a problem before it completely fails.Charlie
Johnson110
Re: 1992 camry
I know it sounds strange but it must have had water in it running for two days now and it runs good, prior to purchasing the car appox 3 months ago it had complete tune-up also timing belt was replaced has 125 k miles, going to put gas in it tomorrow, and see, as of now it runs good!
DaleT
Re: 1992 camry
I had an old Mustang that acted similar, my suggestion is to closely inspect the distributor cap. Mine had a small crack that would allow moisture in, but only on occassion . Once I replaced it I had no further problems.
