clevecan
Thread starter- Joined
- Aug 25, 2008
- 130
E140TLETC
G 03184443
runs great at speed anything over. 1/3 throttle But at idle it seems to idle real low rpm and dies while in gear.
I did comp test 140 lb per cylinder. Did spark test with tester it jumps a 7/16 spark on all 4. I did run some bad gas from tank with water bad trash but had good filters to catch most. Had old gas in tank, drained most but some got by.I have replaced all fuel via draining tank and replaced all three filters 1 being water Sep. Filter. It has the 4 carb setup and have not pull them off.
What should I do next.
Thanks
G 03184443
Thanks
