1992 evinrude 200 problems
HighTrim
Re: 1992 evinrude 200 problems
Did you look at the part numbers I posted in my previous response? Are the non compatible parts being used on your outboard right now?
Joe Reeves
Did you thoroughly check the pins, sockets, and wires?
Pins or sockets, whatever connectors are being used...... something at those connections may not be making proper contact. Check closely all of the connectors between the timer base to the powerpack and from the powerpack to the coils. Pins and sockets have a habit of being pushed back, not making proper contact.... wires fray and break at the pins/sockets but look to be connected because they are stuck in the rubber plugs, etc.
v8etr
hightrim I have a cdi powerpack and a cdi stator the only part that is factory is the timer base. I did check all of the pins and wires and i found nothing.
