1992 evinrude 48 spl
llewis01
I need to remove the lower unit to replace the swivel bracket. Trying to get bolts out. I have 2 bolts out now. The other 2 bolts will not budge. How much or can I use heat to get them out?
Bosunsmate
Re: 1992 evinrude 48 spl
DEpend which bolts you mean, post a photo if possible.
Most of the lower ones you can, but any up near the midsection you risk burning seals or rubber mounts
llewis01
Don't have a pic. But the 2 bolts are the ones closet to the prop and not the shaft.
Thanks
Bosunsmate
Heat it up, any burning will just be old fuel or the exhaust gasket. That gaskets not too badly priced
boobie
Don't heat the bolts themselves. Heat the housing around them for it to expand.
