rjcamel2355
Thread starter- Joined
- Apr 22, 2015
- 236
Hey folks I have a 1992 evinrude 200hp xp model# ve200slens
I thought I had no spark, pulled all the plugs and I have spark on cylinder #4 that's it.
I've disconnected the red plug,no change.
I've disconnected both kill wires no change
starter turns the motor over healthily
compression is 95psi on all 6 cylinders
Here are my test results ohm testing the stator (I do not have a dva but intend to get one). It appears there is some black goop on the back of the motor where the stator wires run down. I believe the stator is bad considering I get no readings when ohm testing. Any help would be great.
Orange to orange black: 107ohms
Brown to brown yellow #1:1018 ohms
Brown to brown yellow #2: 1022 ohms
Connector #1
White to purple: no reading
White to blue: no reading
White to green: no reading
Connector #2
Black white to white: 225 ohms
Connector #1
Connector #2
